Old 06-01-2015, 05:08 AM   #1
PaulDash's Avatar
Question What to inspect before long trip?
In three weeks I'll be setting off on a trip from here (southern Poland), through Germany, Denmark, and into Sweden and Norway. It's going to be a long road trip, about 4000+ kilometers. The "plus", as I want to explore some roads and haven't made plans beyond some business in Oslo.
What should I get inspected before the trip?
The car is serviced regularly and will have its oil, oil filter, and air filter changed. Any other recommended preventative service? Any parts and tools I should have with me on this trip?
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 06-01-2015, 08:24 AM   #2
long voyage
Good luck on your long trip. I hope it is a great one.
I usually take these items when we go on a long trip on our 2000 base Boxster:
an assortment of extra fuses used on the Boxster
tire plug kit & pump
Fault code reader
voltmeter
a couple spare halogen headlight light bulbs
a small tool box with basic tools (especially a 10mm socket & wrench)
the instructions for manually raising the top.
the map of the fusebox
long jumper cables
an extra sepentine belt with a 24mm wrench
quart of oil, brake fluid, water
money
rem503 is offline   Reply With Quote
Old 06-01-2015, 11:06 AM   #3
Giller's Avatar
This about covers the what to take part....
http://986forum.com/forums/general-discussions/55550-porsche-emergency-kit-what-do-you-carry.html
Old 06-01-2015, 04:10 PM   #4
PaulDash's Avatar
Thanks, rem503 and thanks for the link, Giller. I've seen that thread and with this post wanted to concentrate more on the checks.
Still, a few questions:
* by tire plug kit, do you mean the fix-a-flat?
* what is the 10mm socket for?
I always carry the toolkit, a warning triangle, reflective vests, spare bulbs and fuses.
Future: 959
Old 06-01-2015, 05:13 PM   #5
flaps10's Avatar
1) Bank balance
2) Sense of humor
Old 06-02-2015, 04:46 AM   #6
edc
550 Anniversary
edc's Avatar
Each year I do a 2-2.5k mile trip through Europe hooning some of the best mountain roads. It's not a gentle motorway cruise so I make sure suspension and brakes are tip top. Depending on age I would also look at your clutch, waterpump as preventative maintenance. Check for corrosion on the brake lines and the union from the PAS union pipe as this splits
Old 06-02-2015, 07:46 AM   #7
long trip
The tire plug kit is a rubbery strip, rubber cement and a rasp and pick for inserting the rubber strip in a nail hole for a temporary fix. I also bring a tire pump.
The 10mm socket and wrench are useful for many connections you may want or need to access - battery connections, front engine panel nuts and bolts, undertray nuts...
Old 06-02-2015, 08:25 AM   #8
kk2002s's Avatar
Take Serpentine belt off and check all pulleys for any signs of wear especially the water pump and alternator
Spare Fuel pump relay. I would never have thought of this except I had one go bad and it shuts you down. Cheap part, I bought spare to carry with me all the time
I had made a jumper cable to diagnose and I carry that as well so I can jump relays
I brought spare AOS on long trip with hose clamp pliers. I don't know how I would do this on the side of the road but at least I had the option
Fix-a-flat
scissor jack
Bentley manual
a Trailer to carry everything
a support car to follow you
Typically I find when you bring all this stuff, you don't need it. Better safe then sorry
Good luck and enjoy
Seal Grey
Old 06-02-2015, 10:54 AM   #9
Check all the tires for nails or other debris and fix it before you go in the trip.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-03-2015, 08:22 AM   #10
long trip
I like the idea of a support vehicle. As I get older, I have noticed my trips resemble more of an assualt on Mount Everest than a 200 mile day trip to Presque Isle in Erie Pa. for a day at the beach.
