Old 05-17-2015, 08:50 AM   #1
adjusting boxster window horizontally?
My driver side window currently is set half an inch too far back. This is leading to a crazy amount of wind noise. Is there a detailed process for adjusting the window forward?
Truth be told I don't mind too much as I have the windows and top down usually however my girlfriend has ear popping issues and the wind noise drives her nuts.
Lexicon is offline   Reply With Quote
Old 05-17-2015, 09:20 AM   #2
911monty's Avatar
Go to Pelican Parts and search Projects for window regulator replacement. Basically you disassemble the inner door panel,lots of electrical connections and the airbag! Not too bad a project. Inside the door, the window is clamped to the regulator, once inside loosen the clamps to slide fore and aft.
Old 05-17-2015, 05:04 PM   #3
Thanks for pointing me in the right direction!
Old 05-24-2015, 05:45 PM   #4
Usercpy
ilikeching's Avatar
https://www.youtube.com/watch?v=swh72qx4-sg
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
