Old 04-12-2006, 06:26 PM   #1
Question Locking front tire under braking?
After a spirited drive or two over the last couple of days, I've noticed that my front right tire wanted to lock up and skid a bit under medium-hard braking.
When just driving normally, it doesn't pull when braking. The rotor seems worn the same amount as the other side, as does the pad. While the car has pulled right just a tiny bit (towards the locking brake) since I bought it a year ago, it was determined that the alignment wasn't causing it, and it probably was the tire. The tires were new, and have been checked out OK.
If I get on the brakes at speed medium-hard, I hear that tire start to skid just a bit, and the pedal starts to pulse a bit after a 1/2 second pause as the ABS kicks in. Harder braking causes just that tire to complain, with ABS doing its job, but only on that front tire. No other ABS or skidding noises from any other corner.
I believe that this has developed over the last few weeks. It's not my imagination; this is definitely something that is different suddenly. Does anyone have a guess what is going on, or do you have a similar repair story to tell?
I'm hoping it's just a sensor or sticking caliper, but so far I have nothing to go on.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
Old 04-13-2006, 05:26 AM   #2
check your tire pressures.
insite
'99 Boxster
3.4L Conversion
Old 04-13-2006, 09:11 AM   #3
Thanks, I did a couple of weeks ago, but I checked the pressure again, and it's fine.
Jack
Old 04-13-2006, 12:21 PM   #4
Do you have a flat spot on that tire? That could cause the repeated locking.. Or maybe there's something wrong with the ABS sensors on that corner?
BuffaloBoxster is offline   Reply With Quote
Old 04-13-2006, 12:40 PM   #5
Porschekid's Avatar
I dunno, sounds like a caliper starting to freeze maybe? If you can find a cheap replacement it might be worth a try. Normally that pad or rotor would start looking more worn after a while though.
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
Porschekid is offline   Reply With Quote
Old 04-13-2006, 06:43 PM   #6
Thanks for the replies. I'm going to do the following to it myself, in this order, for starters:
- Clean the ABS sensors and connections.
- Power bleed the brakes and clutch with new ATE Blue fluid
- Remove and inspect the calipers, replace pads while I'm there
If it's still acting up it may be caliper time. Dooes anyone know if rebuild kits are available?
Jack
