Old 04-10-2006, 11:21 AM   #1
Michelin PS2 tire pressures for a DE
I've got a DE coming up in a few weeks and wondered what tire pressures others have used with this tire during a DE. Thanks for any help.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 04-10-2006, 08:03 PM   #2
Miken - I ran my PS2s at my normal street pressures 34/35 and they did fine. Hot temps were in low 40s. Ambient temp was 85 degrees.
Chris C Atlanta is offline   Reply With Quote
Old 04-11-2006, 07:16 AM   #3
Thanks Chris..
BTW, did you ever sell your 19" wheels?
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 04-11-2006, 03:58 PM   #4
What in the hell is a DE? Is it a drivers exam or something and they check your tires?
986Jim is offline   Reply With Quote
Old 04-14-2006, 01:56 PM   #5
Driver's Education, high performance driving schools conducted on a racetrack put on by Porsche and BMW (and other) clubs.
Old 05-22-2006, 12:58 PM   #6
pressure
A DE (Driver's Education)is a high performance driving school, usually sponsored by a car club.
I did one this past weekend on Michelin PS2's. I ran 41lbs front and 37lbs rear.I had some previous experieince using that combo. The Boxster was very loose in tighter turns --- you have to use as much of the track as possible. Those pressures worked okay (considering driver error) but nothing changed much when I went to 39 rear and 34 front just to see what would happen. So, with those two extremes under my belt, I would say I would start with Factory specs plus 2 lbs. and work your way up or down depending on the tires and reaction of the car.
twilson is offline   Reply With Quote
Old 04-30-2013, 01:04 PM   #7
jaykay's Avatar
On those tires (18s) I found that I started to melt the tread block at 36 cold but this was on a tight technical track ... hard on tires
You might want to keep an eye on them and take out a couple of pounds for later sessions. Seems counter intuitive but it seemed to work for me at the time
986 00S
