Old 04-07-2015, 09:56 AM   #1
Spring hub clutch options?
What are my options for a spring hub clutch kit? My V8 swap requires going to a single mass flywheel so I will need a spring loaded clutch to a take some load off the tranny. I know Kennedy Engineering makes one, but at $1000 it's a little pricey for me. The guys there told me I should be fine with the stock 3.2L clutch since I'm only swapping in a 5.3L, but the rigid clutch might be a problem. Are are there any cheaper alternatives for a spring hub clutch?
martsink is offline   Reply With Quote
