Old 04-07-2015, 08:56 AM   #1
Spring hub clutch options?
What are my options for a spring hub clutch kit? My V8 swap requires going to a single mass flywheel so I will need a spring loaded clutch to a take some load off the tranny. I know Kennedy Engineering makes one, but at $1000 it's a little pricey for me. The guys there told me I should be fine with the stock 3.2L clutch since I'm only swapping in a 5.3L, but the rigid clutch might be a problem. Are are there any cheaper alternatives for a spring hub clutch?
martsink is offline   Reply With Quote
Old 04-07-2015, 09:20 AM   #2
Does anyone have experience with these SPEC clutches? http://www.********************************************.com/Porsche-Spec-Stage-1-Clutch-Disc-And-Pressure-Plate-Kit-911-3-6l-Box-Parts-PN-RSP901.html
Old 04-07-2015, 12:23 PM   #3
spec experience
I have quite a bit of experience with the spec options.
Give me a call when you have time and we can discuss it in more detail.
Happy to help,
Erik Johnson
(970) 344-7761 phone
Erik Johnson is offline   Reply With Quote
