Old 04-06-2015, 08:29 PM   #21
Originally Posted by 986man2015 View Post
I do notice a "ticking" sound but not sure if that could be a valve that needs to be adjusted or what? Any thoughts? It kinda sounds like a valve but not sure.
This is most likely a sticky hydraulic valve lifter (sometimes called a valve tappet). The hydraulic (non-adjustable) lifter replaced the old-style adjustable lifters where high pressure oil is pumped into the lifter to take up the slack between the valve and the cam.
The idea is that hydraulic valves/lifters are always in perfect adjustment - except when the lifter sticks and won't take up the slack - then you hear the valve tapping on the lifter because its out of adjustment.
To fix this, the cam cover has to be removed and the lifter repaired or replaced. This job is actually more complicated than it sounds because the cams need to be locked in place so the engine keeps timing and so they don't fall out when the cam cover is removed. Also re-sealing the cam covers can be a pain (there is no gasket, just sealant). When you're ready to learn all of the details you can do a search and find all you need to know. Its not an immediate need, but its also something that shouldn't be forgotten.
Old 04-06-2015, 08:34 PM   #22
Originally Posted by healthservices View Post
OMG are you serious? You have not done a search on the "Tick of Death" or "Death rattle"?
Best post of the week!
Old 05-23-2015, 08:14 PM   #23
Thumbs up
Thanks so much for your help.
986man2015 is offline   Reply With Quote
Old 05-23-2015, 08:16 PM   #24
I'm not sure what I'm looking at here. Is that a rock inside the bearing race?
Old 05-23-2015, 10:00 PM   #25
Steve Tinker's Avatar
No, that's a broken piston and its associated cylinder bore !!
The darker grey half circle located just below the broken piston crown is the piston ring.
It shouldn't look like that......
If your IMS bearing collapses, the piston and valves can collide and cause damage as in the picture
2001 MV Agusta F4.
Old 05-24-2015, 10:10 AM   #26
Another option is to do nothing. The early dual row IMSB, up to around 2000 had very low failure rates, less than 1%. The problem is that for MY 2000, there is no really reliable way to determine if you have the dual row bearing or the single row (that has an approximate 8% failure rate) without taking out the transmission and flywheel.
I have a 2000 with a build date of June 1999, so I am fairly convinced I have the dual row bearing and I'm not going to do anytrhing until I have to replace the clutch.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
