Old 02-15-2015, 02:13 PM   #1
Change instrument cluster units from KM to Miles
I recently had to have a new instrument cluster/speedo fitted in my 2000 986 Boxster (at great expense at the Porsche Dealer!) and it seems they've fitted a German speedo rather than an English one as the analogue speedo is in KPH rather than MPH as are all the other units bar the Car's mileage and the digital speedo which have been set to MPH. I can put up with the analogue speedo being in the wrong units as I never use it, but its frustrating loosing the option to have my MPG and miles til empty as they are both in KM. I tried holding the clock switch to the left for 5 seconds to switch the units, but this only changes the Car's mileage and the digital speedo units, not any of the other units for MPG, miles till empty, average speed etc. So before I ring up Porsche to see if they can sort it, just wondering if there's another way to switch these units? Thanks for any advice.
eliot92 is offline   Reply With Quote
Old 02-15-2015, 03:16 PM   #2
Gauge clusters are country specific; if you look in the Porsche parts catalog, you will find an entire list of part numbers by country. You will not be able to reprogram this cluster to do what you want.
Old 02-15-2015, 03:29 PM   #3
Artist, 986S tinkerer
NewArt's Avatar
Ha, if you were closer, we could swap heads! I'm in Canada with a U.S. car and I have the opposite problem. Fortunately Canada used imperial units when I was a kid so I still know what 25 MPG means! As you mentioned, it is not possible to change these other readouts.
