02-09-2015, 03:26 PM
#1
Need For Speed
Spark plug tubes
I just got new spark plug tubes in today. I've never changed them, but my question is, are they solid hard? I always thought they would be squishy? Ordered them from Germany.
02-09-2015, 04:09 PM
#2
Yes, they are rigid.
02-09-2015, 04:12 PM
#3
Yes they are solid/rigid hard plastic tubes. You do have the 'O' rings for them I hope?
Now is the time for ingenuity. Devise some kind of tool to pull the old out.
Have fun
Seal Grey
02-09-2015, 04:27 PM
#4
Need For Speed
Thanks guys. Yes the tubes came with the O rings. Changing my spark plugs too.
I'm planning on using the bolt and washer method from this post.
Spark plug tubes
02-09-2015, 05:18 PM
#5
There Is No Substitute.
Throwing out another suggestion for removing the old tubes, an expanding boat drain plug.
02-09-2015, 06:01 PM
#6
Need For Speed
Saw that one too in the same thread. I have bolts, washers and nuts. If I can't get that to work there is a Marina about 25 miles from me. I assume that is where you would have to get one of those?
02-09-2015, 07:43 PM
#7
98 Arctic silver 986
My O rings were so old that I was able to pull the tubes out with my fingers. I just put my finger in the tube, kinda pushed down and pulled them right out. I was pleasantly surprised how easy they came out. I hope you don't have to much trouble with them.
02-09-2015, 08:05 PM
#8
1999 base
I got it at Walmart
02-09-2015, 08:31 PM
#9
Need For Speed
That would be nice!
02-10-2015, 10:29 AM
#10
Need For Speed
There is no presents of oil leaking at any of the spark plug tubes. So I'm just going to leave them alone.
EDIT: No wonder there is no oil leaking. Was just reading Pedro's spark plug and tube change and I see this.
Note: For model year 2003 and newer, the plastic spark plug tubes were replaced with the metal tubes that only get serviced during engine disassembly.
From the 2003 Boxster Service Information Book - under engine changes:
"The oil protection tubes are now a component part of the valve lifter housing and sealed to the cylinder head cover with formed oil seal rings."
Anyone want to buy a set of spark plug tubes?
02-10-2015, 08:58 PM
#11
Well that was easy
02-10-2015, 09:35 PM
#12
did you keep the walmart receipt to return the bilge plug also?
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
02-10-2015, 11:58 PM
#13
Need For Speed
Actually I found a nifty little tool in the basement I was going to use. The reason I came back in to read Pedro's DIY was to get the connection off the coil pack. Sure glad I did that, could you imagine me trying to get the plug tubes out lol.
BTW: You should see my coil pack post.
http://986forum.com/forums/general-discussions/55792-bad.html
02-11-2015, 08:31 AM
#14
Need For Speed
Why does Pelican show these tubes for
Boxster (1997-04)
Boxster S (2000-04)
Boxster S Special Edition (2004)
When the 2003 up models do not have them?
Porsche Boxster (1997-2004) - Ignition Tune-Up - Page 1
