Old 11-02-2014, 08:01 PM   #1
Jinx's Avatar
Smile Service advice please
In the next few weeks Bill will be
Making a appointment to have
The check engine light code checked.
The code is po491 and Po492
Secondary air insufficient flow
Bank one and two. In reading
Up on this I find it can be a pain
To find the cause of the problem.
We use a few independent guys
Which of course are cheaper than
The local Porsche dealer. My question
Is knowing that the dealer has the
Correct instruments and hopefully
The knowledge to fit the problem
Or problems. Would it be better to
Use the dealer vs the independent
In this case.
Thanks in advance for you opinion.
Bill and Jinx
Jinx & Bill
Jinx is offline   Reply With Quote
Old 11-02-2014, 08:20 PM   #2
While the Secondary Air Injection system has several components (wiring, relay, pump, valves, vacuum lines, and hoses), this is something that a competent Indy should be able to diagnose and repair without too much trouble.
Old 11-03-2014, 01:07 PM   #3
Jinx's Avatar
Thumbs up Thank you
Thstone, thank you. Jinx
Jinx & Bill
