Performance and Technical Chat
transmission output shaft seal replacement?
10-13-2014, 06:12 AM
truegearhead
Anyone have a write up on this? What parts do I need to order, just the seal or do a need a new bearing?
2003 911 C2
NASA HPDE Instructor
10-13-2014, 10:22 AM
2
Meir
1999 base
Meir's Garage
boxster S
Originally Posted by
truegearhead
what transmission are we talking about?
5 or 6 speeds?
10-13-2014, 11:05 AM
3
whitecliffs
Its an easy job to do once you have the gearbox off and if its anything like mine you will need a new bearing, also the oil leak knackered the clutch
10-13-2014, 02:56 PM
4
Meir
1999 base
Meir's Garage
boxster S
[QUOTE=whitecliffs;421517]Its an easy job to do once you have the gearbox off and if its anything like mine you will need a new bearing, also the oil leak knackered the
easy on the 5 speeds. different story on the 6.
10-15-2014, 07:21 AM
5
Bigsmoothlee
Thats an input shaft in the pics. Do you mean the axle seals?
Linear Mode
Switch to Threaded Mode
08:10 PM
