Old 08-12-2014, 07:47 AM   #1
Unhappy Power seat plugs
1998 Boxster. My son's car has plugs under the drivers power seat. These plugs control the movement of the seat. They had to be removed to get under the seat to plug another connector in. My problem now is (my own stupid fault I should have marked them) to find the right connection to each plug. Any help will be grateful.
Thank you,
Bill
irelandmoss is offline   Reply With Quote
Old 08-13-2014, 06:11 AM   #2
Pdwight's Avatar
You mean you cut the plugs off the harness ??
THey are also very interactive with the airbag and seat belt system...if you cut the plug off or even put the key in the ignition with them unplugged you will get a airbag warning light
Old 08-13-2014, 12:08 PM   #3
Not cut just pulled from their fittings. Also the HH, LV, HV tags fell off. I guess due to age. The LE (backrest angle) is working fine. The backrest comes forward and backwards. I need to know where the other plugs go.
