05-15-2014, 07:22 PM
#1
Still leaking
I have a 2003 Boxster. I have owned it for 2 1/2 months now.
When I first cleaned out the interior the carpet was very very wet
Soaked in fact. Drivers side only. Got it dryed out and had the local dealer blow
Out all the drains. In past rain showers carpet was moist. Heavy rain
Today and carpet is again wet but not nearly as bad as before, but still
Wet. sitting in drivers seat wet from middle of back engine cover to
Left edge. carpet is wetter the closer you get to the left edge. Any
Ideas on where to check now. Any pictures and advice would of great
Help to me. Thank you, jinx
Jinx & Bill
05-16-2014, 12:00 PM
#2
The classic leak locations are drains and damage to an area under the lid under which the top sits when in the down position. Lift up the top half way and look back there and see if the rubber gaskets and foam are all intact.
Also test each of the drains yourself with a quart of water. Pour in the area of the drain and see if it all comes out the bottom. Locations here.
05-16-2014, 01:00 PM
#3
Has the rear window been replaced? Either way check to see if water is leaking in around the window.
05-17-2014, 11:42 AM
#4
Just wanted to say thank you for your help. I'll work on it today
Jinx
Jinx & Bill
05-24-2014, 05:23 PM
#5
Beginner
so I cleaned my drains in reverse, I used a wet dry vac to suck the junk out of the rear drains.
2003 S manual
07-11-2014, 02:37 PM
#6
I'm having the same problem on the passenger side, I blew out the drains, checked for tears, still leaking.
07-11-2014, 09:36 PM
#7
mine likes to leak during and after rain the leak is from the seal at the top of the window both near the a-pillar and also at the point where the hinge is located above the window, where there is a seam in the weather stripping. if anyone has any suggestions other than buy a 911 coupe it would be appreciated. one solution I have found which works to drain it after rain it to lower and raise the top to allow any residual water to escape before driving.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
07-13-2014, 01:17 PM
#8
Wet carpet
Soaked in fact. Drivers side only. Got it dried out and had the local dealer blow
Hello Jinx
I had a very wet carpet. I took it out altogether for a while to see if I could track the leek down. The carpet sponge on the drivers side (UK) was full of water. There were 2 places I found were water was getting into the car. The obvious things to check first are the drain holes and to see if the water trays are not torn or have other holes in them. They were all fine on my car. At home I park on a bit of a slope. With the carpets out I was able to check for water after rain. Sure enough each time it rained I had water in the foot well and under the drivers seat. It took me a while to work out but the photos below will show you were the water was coming in and how I was able to stop it.
You can see the open area were the shock absorber is, well I decided to cover this with a flap of old inertube clipped under the rubber trim, I did this both sides. After doing this and waiting to see if I had cured the problem, I found that even after a really heavy rain storm no water came in from this side again. There was another area though that got wet too, that was the bottom of the drivers door on the inside carpet trim. I cured this by pushing a rubber tube down the drivers side door seal at the top, about 16" long. That did the trick for now, the springyness goes out of these rubber seals over time. No more wet door carpet trim. I will proberbly get a new drivers door seal in the near future, but this works ok for now. Hope some of this helps you.
07-13-2014, 04:46 PM
#9
Usercpy
You better take the carpet of, or it never dries....
This is the result if moist stay there for long period.
the leak was from soft top, crack between top and vinyl window from previus owner.
http://www.flickr.com/photos/flickr_ching/
07-30-2014, 03:25 PM
#10
Just wanted to say thank you.
I also covered the shock tower
The leak has stopped.
Jinx
Jinx & Bill
07-30-2014, 06:13 PM
#11
Drill two good sized holed in the floorpan at the base of the wall. In front of the pinch weld  let it drain..
We will be replacing floorpans in these cars in no time!! Just like the 911's and 914's!!
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
