07-20-2014, 10:41 AM
Running into issues with an IMS bearing Change
So, I'm at the point of setting up for the IMS change. I have the tool kit, with the cam lock tools, I've read everything I could find on the subject ( which could be the issue). One article states to lock everything down at TDC with the cam tools and r&r the bearing I bought the Pelican kit, which comes with set screws to pinch lock the
Sprocket according to Wayne's 101 project book. I've spent an hour trying to find an area where all three set screws will bottom on the sprocket. The best I get are 2 out of 3. So does just two work, that being said I can't use he cam locks because I'm no where near TDC.
What's the better method? I see value in both, locking everything makes the most sense, but stabilizing the sprocket at the bearing end has value as well.
07-20-2014, 11:16 AM
Do not use the set screws. Do not follow Wayne's directions. Get a copy of the LN Engineering installation instructions and follow them to the letter.
07-20-2014, 11:23 AM
Thanks, I'm not always a fan of "shortcuts", but stabilizing the bearing end of the shaft made some sense. I'll try to find the LN instructions.
07-20-2014, 11:27 AM
You need to understand that the rear gear on the IMS shaft is pressed on, so pushing on it with set screws is a really bad idea.
Do a Google search for the LN instructions, they are online as a PDF file.
07-20-2014, 05:58 PM
Yep, if that's pressed I can see why you wouldn't want to use the set screws. Great advise, thanks.
07-21-2014, 03:04 PM
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
07-21-2014, 03:59 PM
This actually made me laugh out loud.. LOL I should have stopped in and said **hello** on my multiple trips through PA this year
