Old 07-16-2014, 05:45 PM   #1
Box4two's Avatar
Should I be worried?
Just got the boxster a few weeks ago, in excellent condition, but I guess the engine was never cleaned, this oily residue has me wondering if I have a AOS situation going on, my cel light was on and I just changed my MAF sensor.
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Honey it's an investment!
Box4two is offline   Reply With Quote
Old 07-16-2014, 06:59 PM   #2
Since you dont have any driveability problems, thats good. Pull the codes and post.
I would try removing the Rubber ducts that are oily and check for cracks or rips and leaks. When you put them back on, make sure they seal,properly.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 07-16-2014, 07:05 PM   #3
Box4two's Avatar
Codes were 1128 and 1130, I cleaned the Maf sensor and the cel returned the next day, so I decided to put in a new sensor, I'll know by tomorrow if the problem is solved,
But yes I plan on cleaning the entire engine and checking for leaks as well.
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Old 07-17-2014, 05:13 AM   #4
billj18's Avatar
The conventional wisdom is that 1128 and 1130 are symptoms of a vacuum leak. I was getting the codes almost weekly over the winter, and I checked all of the usual suspects: vacuum lines on the engine, as well as the AOS tube and the oil filler tube. No luck. I finally realized that the codes occurred within a day after refueling. I replaced the gas cap in April, and have had no codes since.
Bill
BJ's BlackBox -- 2001 Boxster
1997 SAAB 900S Turbo
1980 Maxda RX-7
1974 Fiat 124 Spider
1976 Datsun 260Z
billj18 is offline   Reply With Quote
Old 07-17-2014, 08:16 AM   #5
kk2002s's Avatar
+1 on vacuum leak. If you are a DIY owner, this might be an opportunity to do a Throttle body/Plenum tube clean.
This would also let you examine closer for any damaged items that could cause a leak
Seal Grey
