Old 07-02-2014, 02:33 PM   #1
Jinx's Avatar
Tech inspection results
I had a tech inspection done this morning for a DE to be run in August.
I did it early as I did not want any surprises and Purchased the car in
March 2014. 60200 miles on the clock.
Please advise especially on the cv boot remark.
Service wrote. Right inner cv boot clamp loosing slinging grease cleaned
Up grease. Tires all 7/32. Brakes front 10- b. rear 8-b.
Passed inspection.
Service manager said don't repair boot until it breaks. Or
Wait until early next year.
Comments please. Should or can I just have the boot replaced
And save the joint?
Is 7/32 ok for the tires
Comment on the brakes. I would have thought the fronts would wear
Out faster than the rears.
This is a daily driver car 1,000 miles a month per month.
Thank you,
Jinx
Jinx & Bill
Jinx is offline   Reply With Quote
Old 07-02-2014, 03:05 PM   #2
7/32's on your tires is fine. Most new tires are 9/32's.
Maybe the boot needs a new clamp or zip-tie. Cheaper to replace a boot than a joint. Want to keep the dirt out of the joint. Front brakes might have more beef on them, because they are newer????
Was your brake fluid flushed at the inspection? Must be done, if not.
Old 07-02-2014, 03:35 PM   #3
jsceash's Avatar
New Nitto NT01 Dot 100 have 6/32" new I just replaced a set after 18 on track days with new Hankook Ventus Z214 Dot 40 R tires have 4/32" Your tire are not an issue.
I agree with flavor 987 if the clamp is just loose. If it's torn I'd replace the boot Asap. New CV bearings are about $200, boots and clamps are as low as $20
Old 07-02-2014, 04:32 PM   #4
Jinx's Avatar
Nothing noted about the brake fluid. I checked
And the color is very clear. It is in fact hard to
Tell it's level. Nothing noted on previous service
Records about fluid flushes behind done.
I just ordered from Pelican Parts a boot,
Inner and outer clamps and grease for
$18.75. I'll have my local import guy
Install it. Since I am not following the
Dealer's advice by not waiting for the
Joint to fail.
Thanks to all. Jinx
Stupid question why would the dealer tell me
To wait? Of course my FORMER local guy wanted to
Know why I was replacing my headlamps from
Stock to Sylvania Silverstar ZXE's . I no longer
Use him for my service.
Jinx
Jinx & Bill
Old 07-02-2014, 05:02 PM   #5
Plus, "slinging grease and DE" are never a good combo.
You need a brake fluid flush. Our local PCA rules require this prior to a high speed event. Most do. Be safe.
Old 07-02-2014, 05:20 PM   #6
jsceash's Avatar
Nice looking car. I think you made the right choice. Your in the ARPCA region check and see who they use.
Old 07-03-2014, 02:54 AM   #7
Jinx's Avatar
Thanks to everyone for the quick responses.
Scheduling the flush and boot replacement
Today. Please have a great and safe fourth.
With love
Jinx
Jinx & Bill
Old 07-07-2014, 10:14 PM   #8
b55er's Avatar
I've heard that using other than the stock halogen bulbs will cause the lens to burn brown from the inside. I use ZXE's on two of my other cars, but have spoken to several dealer mechanics who strongly recommended that I not use them on my 986. I'd love to put them in, but I don't want brown lenses.
b55er is offline   Reply With Quote
Old 07-08-2014, 05:59 AM   #9
seningen's Avatar
Passed inspection.
And save the joint?
Thank you,
Jinx
Check the rules with Boxsters and helmet clearance.
A lot of groups require the broomstick test -- that is sitting in the car
with your helmet on, can you run a broomstick over your roll bar to your windshield
and not touch your helmet.
In the unlikely event of a roll over -- you certainly don't want your helmet acting like a roll bar.
Find the Chief Driving Instructor for your group that you are running with and ask what their rules are if they are not clearly stated somewhere.
You have plenty of tire -- in fact too much :-) More importantly -- how old are they and are there any signs of cracking on the sidewalls, esp near the tread line.
I like to have a fresh oil change and run thick oil -- (especially in August)
Make sure your radiators are cleared of any debris.
Check your power steering fluid level. Inspect your serpentine belt and clean replace your air filter.
Have fun,
Mike
mike@lonestarrpm.com
Old 07-08-2014, 06:36 AM   #10
Jinx's Avatar
Seningen,
Thank you for the advice.
Jinx & Bill
Old 07-09-2014, 06:20 AM   #11
Jinx's Avatar
ZXE headlights
I regard to our headlight upgrade: Bill and I wanted to see
Further on down the road and also onto the shoulder of the road.
I live in the country. No houses or street lights or other cars for
That matter. Just big corn fields where the deer love to
Roam and jump out in front of you or over you or into the side
Of your car. You can come across a horse or a cow now and then.
but mostly deer or Sometimes a buck with a really big rack.
Yes I do hunt) We use the running lights during the day.
(The first notch on the lamp switch).
Bye for now. Helping Bill clean the Boxster for the Pittsburgh
Vintage Grand Prix at Pitt Race this weekend. (Search PVGP under
General discussions).
Bill get back here and no you can't, not with my Martha Stewart
Towels. I wondered where they were going. Have to watch him
Like a hawk. Ok where is my toothbrush?
Would not want to hit this guy. He's taller than the Boxster.
Jinx & Bill
