07-25-2014, 12:37 PM
#1
In fact, I picked up two C5 corvette differentials I was going to use,
no strength issue there, just more fab work and expense.
Don't take this the wrong way  (I'm ribbing you like a brother would tease you)
You ARE on CRACK
NO way in hell that Nitrous Vette is running the stock trans/rear end
How many times did it shift in the quarter? ONE time. That means it's a two speed power glide. Those transmissions have a really tall first gear (softer launch to keep from blowing the tires off) and the 1-2 upshift is non-violent because of the ratio split between the two gear sets is tall. This allows him/us (I've worked with Pro Stock teams in the past) to control wheel spin on a small tire
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
07-25-2014, 12:38 PM
#2
I like your thought process  Stick with the Boxster. You have a good idea
Think this way: two power train modules. One for front, one for rear.
This: two Prius setups.
07-25-2014, 01:39 PM
#3
If you've seen these C5 differentials, the axles shafts are huge.
What makes them particularly great for an electric motor setup is they have the transmission bolt to the differential with a shaft input, so putting an electric motor in place of the trans is perfect, direct shaft input from the motor,
This is my secret btw, when the next guy builds an electric car with one remember who told you first.
Chevrolet Corvettes and Independent Rear Suspension - GM High-Tech Performance Magazine
A Prius transaxle is not going to handle 400hp. They have two motors in them which is not needed, chain and gears not really needed, and weigh 300lbs. However, some of the parts can be used if you are clever and like to fabricate as I do,
just a big project that needs a sponsor.
07-25-2014, 04:25 PM
#4
Yes
I'm well aware of the layout  Not any different than a 928  ... from 1978...
That is very slick.. the way they are adapting the 4L80E (which is in my 3/4 ton truck)
Way way way to much work.. lol 930 4 speed (you wont shift it) handles 800lb ft of torque no problem. The ring and pinion is the same size as a Ford 9 inch
02-26-2015, 03:21 PM
#5
Nimble,
What is the update on your project? I am thinking of starting on a similar project to convert my 2004 Boxster. Have acquired a Warp 9 (don't want/need a drag racer) and charger, cntroller and other electric conversion stuff from another guy who converted his 1994 911 Carera. I will need an new adpater plate and batteries and all the good stuff. I am plannign to use the 986 5 speed TX...
What batteries are you using and how many? I see you are using an AC motor. BTW where did you get the adapter plate built?
We should connect and compare notes...
04-21-2015, 10:29 AM
#6
The car has not been completed and is for sale. Going to part it out soon if no reasonable offers. I have a 9in DC motor in the car. Maybe you can use the trans adapter in your car.
04-21-2015, 10:59 AM
#7
Mind sharing why this project failed? If not no worries mate... could be medical or private we'll understand. Just curious whether it is due to the complexity, R&D cost, parts cost, etc...
Good info in case someone else wants to tackle a similar project. Personally I'm just curious
Thanks for the update btw and luck with the part-off mate
04-21-2015, 12:13 PM
#8
I don't have the time for it, I'm totally focused on a different project,
Nimble Motorsports Home of the Indy One Electric Kit Car
04-21-2015, 01:06 PM
#9
Which 9" motor have you used? If it is a Netgain Warp 9, I would be interested in the TX adapter if adapted to a 968 5 speed manual transmission. Please send me pics and price if you want to sell it separately. Who did you get the adapter from? Please PM me and I can send you my contact info. Thanks.
| Thread Tools |
| Display Modes |
Hybrid Mode
