Old 06-22-2014, 07:58 AM   #1
DennisAN's Avatar
LN crank lock too long - OK to cut it down?
Sorry to ask yet another question. I've found I can't maneuver the black-handled LN Engineering crank lock tool into position: it's too long to fit. Probably not a problem with the 911 but the Boxster panel behind the seats gets in the way.
I have a stubby 5/16" drill which is almost exactly 8mm in diameter - the diameter of the crank lock tool. It fits in just fine and bottoms out at approximately 45mm deep when measured from the front of the crankshaft pulley. I put some tape around it and you can see where I marked it with a Sharpie.
My question: is there any reason I shouldn't cut the end off the LN crank lock tool, making the rod have a length approximately 45mm from the end to the black plastic handle?
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
