Old 06-08-2014, 12:05 PM   #1
1999 986 hot start problem
Hello,
could someone help me with problem on my Boxster 1999 2.5l 45000km Europe verison?
1. if i could start hot engine maybe 1-60minutes after the drive, engine starts normal-fast, but engine rev goes at first to 1800rpm and then drop to 200-300rpm and then engine stopped. Sometimes i must restart 5 times, until engine drop only to 400rpm, then goes to 1200rpm-600rpm-1000rpm, then correct idle speed. Sometimes i must push to gas pedal.
I changed these on my car: new spark plugs, new MAF sensor (Bosch), new idle speed regulator, new thermostat, new air intake temperature sensor, new coolant temperature sensor, new fuel filter, new K&N air filter, new lambda sonde (im from Europe, so on my car are only 2 sensors, but i changed 1, which was bad). Also i checked fuel pressure, fuel pump rele, all is OK, zero mistake at diagnostic.
Thank you very much for your help and any ideas
david986techart is offline   Reply With Quote
