Old 06-08-2014, 12:05 PM   #1
1999 986 hot start problem
Hello,
could someone help me with problem on my Boxster 1999 2.5l 45000km Europe verison?
1. if i could start hot engine maybe 1-60minutes after the drive, engine starts normal-fast, but engine rev goes at first to 1800rpm and then drop to 200-300rpm and then engine stopped. Sometimes i must restart 5 times, until engine drop only to 400rpm, then goes to 1200rpm-600rpm-1000rpm, then correct idle speed. Sometimes i must push to gas pedal.
I changed these on my car: new spark plugs, new MAF sensor (Bosch), new idle speed regulator, new thermostat, new air intake temperature sensor, new coolant temperature sensor, new fuel filter, new K&N air filter, new lambda sonde (im from Europe, so on my car are only 2 sensors, but i changed 1, which was bad). Also i checked fuel pressure, fuel pump rele, all is OK, zero mistake at diagnostic.
Thank you very much for your help and any ideas
david986techart is offline   Reply With Quote
Old 06-08-2014, 05:45 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
Look a little further down in this forum. This topic was very recently discussed. Possibly fuel tank purge valve.
