Old 05-11-2014, 02:23 PM   #1
RBrummer's Avatar
Boxster 3.2 S Intake problem when cleaning throttle body
Decided to cleaning the throttle body and in the process of removing it, I noticed a sloppy connection in the intake system just prior to the body. Here is a description, following the air flow from filter to throttle body.
Starting at the air cleaner, past the air sensor and just before the throttle body, there is a Y that attaches to a squarish box right at the back of the engine compartment. The connector is almost the same size as the main tube and is held in place with a hose clamp. If you take the box out- it has no obvious use- it is hollow with no connection other than to the intake.
The box has the male connection and the intake Y has the female. There appears to be a compression fitting bump molded into the plastic of both male and female. The male also has a metal ring inside the connection.
It appears it was intended to be a tight connection (esp since it is in the intake upstream from the air sensor). I cannot get the two parts to mate deeply enough to get past the molded compression bumps and get a good seal before putting the clamp back on. That is the way I found it- poorly connected.
Anyone else have this problem.
RBrummer is offline   Reply With Quote
Old 05-11-2014, 04:04 PM   #2
RBrummer's Avatar
Added a picture
By the way it s a 2000 S
Hopefully this will help. Connecting the box with the red arrow to the long runner is the issue.
It is such a tight fit, I cannot mate the two parts.
Old 05-11-2014, 07:13 PM   #3
Artist, 986S tinkerer
NewArt's Avatar
Oh yeah! This fitting is a real SOB to get together! I did this same job just the other day. I used a wooden pry-bar (read "stick") with another long screwdriver and a lot of force and some very choice words to get that mother to snap into it's lodging. It does fit. You have to get the right angle and a fair amount of pressure and it will snap into place. Then you get to try to mate the screw with the hole in the support bracket. I ended up stripping the original bolt but remedied the situation with a ¼" tap and a standard ¼" bolt afterwards. Don't give up. There is hope!
Old 05-11-2014, 07:44 PM   #4
rdass623's Avatar
what is that square-ish box, some sort of resonator to reduce the intake noise? seems to me like it world a prime target for weight reduction. with the weight savings you could pick up ypur 1/4 mile times by at least 0.00000002 secs.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 05-12-2014, 04:20 AM   #5
RBrummer's Avatar
NewArt
Thanks- that gives me hope and a sense that I am not alone in the Boxster universe with this problem.
RB
Old 05-12-2014, 04:22 AM   #6
RBrummer's Avatar
rdass632
I think that is its sole purpose in life.
I will weigh it and get you its exact weight so you can more carefully calculate its predicted net gain in the 1/4 mile
However, I would have to plug the hole with something else, so that might offset the gain
Old 05-12-2014, 07:33 AM   #7
rdass623's Avatar
rbrummer, you are from florida, I am from Louisiana, there is Alabama and miss between, just take the advice of the neighbors in between...... duct tape. it would be a first, actually using it for the engineered purpose, but what the hell
Old 05-12-2014, 05:01 PM   #8
RBrummer's Avatar
Got her done
rdass623
Duct tape was very high on my list, but I too am as German and as stubborn as my German car, so I pulled out the long piece of intake pipe, put both on the bench, borrowed my wife's hair blower, heated up the "female end", applied a little lithium grease and some elbow grease. Once "mated", I took them apart, stuffed them both back in and re-introduced the happy couple. I would only recommend this on inanimate objects.
Now waiting for Pelican to deliver some gaskets for the throttle body/intake runners and a new MAF sensor for the rough idle and we will see what happens.
Collateral happiness is that I now know exactly where the starter is and if/when I fails, that should be a piece of cake.
RB
Old 05-12-2014, 08:50 PM   #9
rdass623's Avatar
RB as a fellow schnitzel eater and former helicopter mechanic, I also have a stubborn streak for getting things right, but I probably would have resorted to the band saw and some fiberglass resin for that resonator before resorting to a hair dryer. a little more intake note is always a good thing. on my Miata, I found the only replacement for the mentioned intake note was the whine of a supercharger. now all I need to do is make my boxy accelerate like my Miata...
Old 05-13-2014, 02:48 AM   #10
RBrummer's Avatar
I had the same problem stripping the bolt
Thanks for the tip
