Old 04-26-2014, 08:02 PM   #1
exhaust smoke
at the track today I noticed some occasional puffs of white smoke coming from the exhaust under hard acceleration / high revs. other than that it runs and drives fine.
rings, seals maybe? anyone had anything similar?
thanks
kiyakubuke is offline   Reply With Quote
Old 04-27-2014, 01:29 AM   #2
Steve Tinker's Avatar
Possibly air/oil seperator (AOS) failing. A quick test - with engine hot and idling, try removing the oil fill cap - if its difficult to remove (vacuum present) its the AOS.
Some track people also use a competition AOS, and deep sump kit to help combat oil surge in the sump and if you'r really keen an extra anti-surge oil pump in the cylinder heads + pressurised supplimentary oiling system.
Use the search function for more info or see Boxster Racing Forum section.
2001 MV Agusta F4.
Old 04-27-2014, 12:20 PM   #3
it wasn't very hard to remove the oil fill cap, but there was certainly a vacuum. could hear it, feel it when I put my palm over the hole. also, the rpms went up when I removed it, back down when I put it back on.
