Old 04-21-2014, 05:20 PM   #1
Send a message via Yahoo to Chard
Will these wheels fit?
Front: 18x8 45 mm offset 225/40/18
Rear: 18x10.5 45 mm offset 285/30/18
Car is a 2000 Boxster S, stock height
Present:
'08 e90 335i, '00 986 S
Past:
'99.5 B5 A4 1.8tqms, '02 e46 m3 convertible
Chard is offline   Reply With Quote
Old 04-21-2014, 05:36 PM   #2
golonaus's Avatar
With 10" rear I'll say yes flash with the fenders
With 10.5" it might be just little too wide
99' with 3.4l engine. ROW tune. SAI delete
Old 04-22-2014, 07:39 AM   #3
BruceH's Avatar
I have 10" rears and they just fit. I would not want to go 10.5". Yes, it's that close to the shock tower. My offset is 45mm(rim is ET65 and I have a 20mm spacer). The fronts should be fine.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-22-2014, 10:23 AM   #4
that's a bummer... I thought i found a good set of wheels. OK, thanks for the replies guys!
Present:
Past:
Old 04-23-2014, 07:07 PM   #5
Factory rims are like 7.5"in. In the front , 9.5"in. In the rear. With factory recommended tires, actual tire contact on pavement is 8"in. In the front and 10"in. In the rear. It works perfect for me since I don't have twin turbo's .lol. A simple factory spec'd 3.2 litre.) I have enough grip action to keep me satisfied.
RickG is offline   Reply With Quote
Old 04-24-2014, 12:31 AM   #6
Rears wil fit just fine. You will need spacers though. I was running 10.5 rears ET32 with no problem on a lowered Boxster. Tires must be 265.
Edreamsz is offline   Reply With Quote
