Old 04-20-2014, 07:30 PM   #1
embryoguy@mac.com's Avatar
slight squeaking sound at start up
so i recently started to hear a slight squeal sound at start up. its not loud but noticeable. it only last for about a min, and after engine warms a bit its gone.
should i be concerned? thanks in advance.
embryoguy@mac.com is offline   Reply With Quote
Old 04-20-2014, 07:52 PM   #2
oc-boxster's Avatar
If it sounds kind of like a hair dryer by your passenger rear tire and It stops after 2 minutes or so it's your sexondary air injection pump
oc-boxster is offline   Reply With Quote
Old 04-20-2014, 07:53 PM   #3
yeah thats what it sounds like. so is that ok? or sign its about to go? thanks for your input.
Old 04-20-2014, 08:03 PM   #4
oc-boxster's Avatar
No it's a normal sound and you should hear it on every cold start.
Old 04-20-2014, 08:08 PM   #5
ok thanks very much ! i can sleep now lol
Old 04-21-2014, 06:51 AM   #6
kk2002s's Avatar
Hate to ruin a good nights sleep. The air injector is one sound that is expected but there is a bearing in it that can go bad. I'm starting to hear a very high pitch squeal while the injector is running. So I suspect that the bearing that the injector runs on is going bad
Seal Grey
Old 04-21-2014, 11:12 AM   #7
Yep, eventually it will start throwing codes. Theres a write up over on rennlist on how take the pump apart and lubricate the bearing that goes bad.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-23-2014, 11:23 AM   #8
kk2002s's Avatar
Well last night I took my SAI-pump apart and using a Lube Needle, filled the motor bearings with grease.
I started and no high pitch squeal, just regular hair dryer sound and that with engine cover off so I could hear very clearly
So time and more starts will tell.
It seems all I do is repair/replace sealed bearings.
My table saw, my jeep's AC compressor clutch pulley.
These dried out creatures are everywhere
Good write up on rennlist
Seal Grey
Old 04-24-2014, 02:08 AM   #9
Mine is more of a hum than squeal...you might want to lube it as kk did or you might be buying a new pump.
