Old 07-19-2015, 02:34 AM   #1
Curtesy lights pin out
Hi Guys, does anyone know which wire at the ecu becomes live when the car is unlocked/opened that power up the curtesy lights in the doors? I am building a transparent engine cover and would like to fit LED strip lights in the engine compartment that light up when the door lights do.
I know I can probably trace a wire where it enters the door, but if I can pick this wire up at the ecu, it will make what I'm trying to do, a much neater and easier job.
any help will be appreciated.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 07-19-2015, 02:44 AM   #2
Brown wire with yellow stripe at the immobilizer under the seat.
Old 07-19-2015, 03:06 AM   #3
Thank you! Im installing a switch in the centre console so it will be really easy to route!
