Old 04-13-2014, 08:40 PM   #1
Headers. Coolant line modification on 986's with Tip.
I bought headers and the drivers side went on easy enough. The passenger side is a pain. There are coolant lines in the way. Max speed says their headers won't work because of the coolant line. Fabspeed says " NOTE: Slight modifications to the factory coolant line are required on vehicles equipped with a Tiptronic transmission." Mine are knock offs. Does anyone know what mods are to be made. Any pictures? Thanks for the help.
Josephjochoa is offline   Reply With Quote
Old 04-18-2014, 10:55 AM   #2
Registered Boxster abuser
healthservices's Avatar
maybe you can show the pictures as to where the interference is?
sounds easy enough to bypass... no?
Old 06-09-2014, 04:14 AM   #3
Did you get this sorted out?
I had this exact same problem and had to have a custom line made. I can get some pictures in a week or so when I have the car back on the lift if needed.
JoshC is offline   Reply With Quote
