Old 04-01-2014, 07:16 AM   #15
BruceH's Avatar
Take a look at the May, 2014 Tech Notes in Excellence Magazine. There is a good write up on this debate under "Anxious Pump Watcher". Here is a quote,
"Although one problem is solved with a metal impeller, it creates a worse situation, because the crankcase cannot be repaired."
They suggest replacing the pump every 50,000 miles or every 4 years, whichever comes first, and use the Porsche genuine factory pump. They go on to recommend a complete drain, flush and refill of the coolant system every two years. Too many bad things can happen when a metal impeller comes loose.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
