Old 03-23-2014, 05:18 PM   #1
jrcui's Avatar
Had this in DIY... Looking for guide to replace rear sway bar bushings
Did search couldn't find DIY for rear sway bar bushing replacement
jrcui is offline   Reply With Quote
Old 03-23-2014, 06:45 PM   #2
jsceash's Avatar
It's that simple. Disconnect the drop links unbolt the cap slide off the bushing reverse for assembly. A little lithium grease will aide installation and squeaks later
Old 03-23-2014, 08:06 PM   #3
jrcui's Avatar
Perfect. Mahalo!
Old 03-24-2014, 12:52 AM   #4
Steve Tinker's Avatar
You need to jack up both rear wheels before you disconnect the drop links and disconnect the sway bar.
If one or both wheels are sitting on the ground, the sway bar is under tension and difficult to remove.
2001 MV Agusta F4.
