Old 03-01-2014, 07:54 PM   #1
brake job
Here's my new brakes and rotors. I still have to wait for the weather to turn good before I can break them in. Took about 2.5 hours
http://www.986forum.com/forums/images/smilies/cheers.gif
Old 03-02-2014, 02:33 PM   #2
woodsman's Avatar
Just enough time to clean up those rusty nuts!
Old 03-02-2014, 03:00 PM   #3
Hard to tell from the pics but the rotors appear to be slotted and drilled is that correct ?
rfuerst911sc is offline   Reply With Quote
Old 03-04-2014, 08:22 PM   #4
any suggestions on how to dress up the lug nuts?
Old 03-04-2014, 08:23 PM   #5
Yes they are. for $217 for rotors and ceramics shipping included I felt it was worth a try on a 99 Boxster that doesn't experience aggressive braking. I read several comments on here from others who tried this low cost brake kit and were pleased with the results.
Old 03-04-2014, 09:14 PM   #6
Great job! Its amazing how easy it is to save yourself $400 in labor!
Old 03-04-2014, 09:38 PM   #7
jrcui's Avatar
Thinking about trying to do the brakes myself too... And to dress up the lugs, check this out ColorLugs - Home
I have black ones covering up mine and hide the nasty lugs nicely.
jrcui is offline   Reply With Quote
Old 03-05-2014, 03:57 AM   #8
landrovered's Avatar
Covering rust with a cap that will retain water and grime is never a good idea. The best thing to do is either purchase anodized lugs or paint the ones you have.
2001 Boxster S 3.6L, Zeintop
Old 03-05-2014, 03:28 PM   #9
What type of finish do the lug bolts have from the factory ?
Old 03-05-2014, 06:11 PM   #10
Black OEM lugs are anodized. I assume the silver are as we'll but cannot confirm that. Here is a link to Porsche lugs which says to use soft sockets and paint them if they get nicked. https://www.****************************************************.com/product/LUGNUT.html
Old 03-05-2014, 06:23 PM   #11
Ckrikos's Avatar
The rusty nuts are easy to fix. I have been cleaning my wheels and wheel wells and removed the lugs, brushed them with sand paper and a wire brush then quickly sprayed them with duplicolor. I went over them with 2 or 3 coats and they look great. I'm not sure how long the color will last as I didn't clear coat it, but I think they should be fine.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 03-05-2014, 08:06 PM   #12
I was wondering about anodizing. The paint will nick on the edges of the lugs the first time they are torqued down.
Old 03-06-2014, 06:09 AM   #13
I've been using the caps for a few years with no issues. Spray the heads of the lug bolts with WD-40 before you put the caps on, otherwise they can be tough to remove.
'99 black 986
Old 03-10-2014, 11:42 AM   #14
Beginner
Jamesp's Avatar
My lug bolts were painted steel. Repainted them and they look fine.
2003 S manual
Old 03-10-2014, 01:23 PM   #15
Mine have a healthy dose of patina. They are staying that way too.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 03-10-2014, 01:56 PM   #16
I had that once too but the doctor gave me some cream and it went away.
'99 black 986
Old 03-20-2014, 12:41 AM   #17
I went with a $200 kit myself. Installing it now. After seeing all the $500-$800 kits, I figured I'd give the generics a shot and see how they do. Have only done the backs so far and am still working on replacing all the control arms so haven't had them out yet. The quality looks good though and the car won't see a single lap at a track so why not...
Also, I strongly recommend doing your own brakes. It's easy, enjoyable, and a great way to get your hands in your car even if you've never once held a wrench. Use the $400-$600 you save by doing it yourself to treat your girl to a mini stay-cation out in town.
sam c. is offline   Reply With Quote
Old 03-20-2014, 09:09 AM   #18
lkchris's Avatar
Used nonmetallic wheel on Dremel to clean mine. (Eye protection). Rust hardly occurs where I am and this was mostly brake dust. Now all match the four new ones that replaced the wheel locks I didn't want.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 03-20-2014, 07:23 PM   #19
the brake set is working outstanding. More stopping power than I had with the worn factory set. Look great. quiet and reliable.
Old 03-20-2014, 07:51 PM   #20
98 Arctic silver 986
tommy583's Avatar
Good to know. I was wondering about how well they work compared to stock.
