Old 05-15-2014, 01:40 PM   #21
Trey T's Avatar
^Their statement is relatively true but they're speaking very conservative there. If you just put a dab like I mentioned above, you should NEVER have misfire. The issue is quite simple: the surface area of the threaded portion is probably 50x the area of the end of the sparkplug; there's plenty of grounding surface there.
Trey T is offline   Reply With Quote
