Weird Issue: Not turning over... Tried everything
As the title states wont start but here's the details.
So i bought a 98 with a bad motor and swapped a good one in (both 2.5 ect). Everything worked fine for a few weeks while in the garage but after pulling it forward and back a few times it wont start at all now. I replaced my ignition switch (the mechanical and electrical) with a known working one out of my old wrecked car. I can jump the starter and it turns over (doesnt fire) and sparks so its not the starter. Is there a fuse or relay for the starter? would it be the clutch sensor not working (meaning it thinks the clutch isnt engaged?). I just dont understand how everything works fine then nothing. Interior lights all work, headlights ect, the battery is charged. snt Any ideas on what to check? it started easy before and now jumping the starter isnt starting so im thinking the fuel pump ect isnt kicking on. I never replaced the black electrical box on the ignition, i think its the immobilizer. Could that be the issue as its the same original one. Thanks guys and if you can help and need parts let me know i have a wrecked one i parted out that id be willing to help you out in return. Thanks Brian |
Do you have fuel pressure? You can pull the fuel QD at the lower left firewall and you should get squirted with gas, if you don't you have a bad fuel pump.
And the title says it wont turn over, but the post says it does. That is a little confusing.
So the starter turns when 'jumped' but not when you turn the key?
Fuel pump- you should hear it start after turning key on and there's a Schrader valve fitting on the right fuel rail for a pressure tester. The main DME relay is in the trunk and I think this can cause 'silence' with key-on. |
Can you change the clutch interlock with another?
Often the first think to let us down is the last thing we fixed. IE- a loose ground or other wire/ connector. |
Yes correct it only turns over when jumped
Yes i hear a humming when the key is to the ignition on selection and I dont have a clutch interlock as the wrecked one was triptronic Other thought: it seems like a anti theft or kill switch b/c everything worked (approx 10 starts over 2 weeks) and did nothing different or changed anything to make it not start. Everything seems correct except it does not turn over. I have to double check the fuel pump though as the humming noise could be something else. Quote:
I did close the top from the service position before it quit starting but i then tried it with it back in the service position, up down and all positions out of desperation but still no click or noise from the starter.
Also this may help, when it was starting it had a bad mechanical ignition switch and didnt spring back once started so the starter was still engaged while it was running. Would this of fried a relay? It was never running more than 5 minutes. Tomorrow morning i will bridge the clutch micro switch to see if thats the problem. Does anyone have a relay diagram so i can check the starter relay |
My guess would be the clutch switch. This happened to me once and it was just the floor mat stuck under the pedal. :rolleyes:
Just tried the micro switch. 1 holding it down... nothing, and then i used a wire to jump the two posts and still nothing so this seems to be good.
So Summary: - Doesnt start, no click or noise what so ever, all interior/dash lights work fine - If the starter is jumped it will attempt to start but wont fire (acts like dosent get gas) - Ruled out ignition switch (mechanical and electrical), battery and clutch microswitch Possibilities: Immobilizer, key?, ground wire? (although i checked all the ones i could find), Prior to problem: -Engine was replaced, then worked fine for a few weeks after new engine was put in(started first time everytime) -Ignition mechanical switch was bad, wouldnt spring back after started -Before the engine replacement everything worked as should with the starter just didnt fire Quote:
Sounds similar to my issue only mine is intermittent. When my problem occurs I am able to roll the car and pop start it in second gear.
Sent from my SM-N900P using Tapatalk |
Update: replaced the fuel pump relay (13 in foot compartment), dme relay and the start lock relay (1,7 in trunk)
Still nothing, I also checked for any error codes with my obdII and nothing Also the fuel pump is not kicking on (why i changed the relay) Does yours start after the initial rolling start? Quote:
Yes mine starts when push started then subsequently starts with the key fine until it decides not to.
What method did you use to "jump" the starter?
I actually connected wires to the positive and solenoid, ran them into the cabin with a momentary switch. Works well to crank the starter over but when my car is experiencing the condition the starter spins but it still won't fire. But the car will still roll start.
I used a screw driver to make sure it was getting juice and worked.
Its not getting fuel as well though b/c it fired 1st time every time before that, jumping it doesnt even try to fire other then turning over Quote:
got schematics and a voltmeter?
I know its been awhile but it was a rough winter here and didnt get much time to get to the garage.
Yes i have a voltmeter but i dont know where to start. If the immobilizer when bad what would happen? I'm thinking this is what went bad, or the ecu itself. The person i bought it off of said it was rechipped with a performance chip but i find it odd why it worked fine for a couple weeks. Changing the original trans from this engine from auto to manual shouldn't of made a difference since the engine part#'s are the same. This weekend i'll try the rolling/pop the clutch to see if that starts it but i kinda doubt it since the fuel pump didnt seem to be kicking on either with the starter |
When you swapped ignition switches, did you swap keys as well? If so, did you swap the innards of the keys?
If you changed the entire ignition switch (not just the electrical part) and the keys, you need to remove the metal key from the fob and install the metal key in your old fob (remote control).
| All times are GMT -8. The time now is 11:40 PM. |
