Old 02-03-2014, 03:24 AM   #1
Avoid at all costs Performanceremap.co.uk
Just a warning to others looking to get there Boxster remapped after upgrades etc.Do not use Performance Remap - Mobile ECU Remapping Services In Gloucestershire based in Gloucestershire.He is a mobile guy who is cheap but he is the most unreliable person I have ever had the misfortune to meet.Had 4 appointments with him and he failed to turn up for 3 off them!
1st appointment -canceled at last minute as he was "delayed" and re-booked
2nd appointment-He turned up but had to be told where the OBD port was as he was looking on the drivers side.Bit strange as he said"I have done loads of Porsche's"He could not get access to the original map so left to get one.Fair enough.Called later that day and re-booked.
3rd Appointment- canceled at last minute due to a "headache" re-booked
4th Appointment-canceled last minute due to being "delayed" and would keep me posted,heard nothing. Text him to next day to tell him my patience had run out and I was going elsewhere. So getting the job done buy
100% failure
getting him there when he says
75% failure
Wasted nearly a month on this person so if you real want the work done, find someone else.
Told him its simple, if you can`t cope with your workload don`t take so much on!
jasonbib is offline   Reply With Quote
Old 02-03-2014, 10:34 AM   #2
edc
550 Anniversary
edc's Avatar
Make sure you know what you are buying. I had mine custom mapped using the dyno. If you have had mods that is the way to go.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
