Old 02-02-2014, 01:40 PM   #1
Question need some help
A 1998 Porsche Boxter. Tach, speedo, ect. does not work. I was told that it could be either the instruments or the ignition switch. Both were replaced and the problem persists. Is there a relay for the instrument cluster, if so, where would it be? This is really getting to be a PITA. Please help.
irelandmoss is offline   Reply With Quote
Old 02-03-2014, 06:02 AM   #2
chrismmm's Avatar
i just pulled my gauges yesterday, removed the red background and replaced it. When i was putting it back into the dash, there was a connector loose. its the only one for the gauges. I pulled it again. reseated the connector. all ok. By the way. I dont not have to fully put it back together before I knew it was working. After reseating the gauges.. all gauge lights came on while i was still holding it in my hand. good look. removing the gauges piece is not that hard. perhaps you can find a diy article on pelican parts. Good lucjk
Chris M
2007 Boxster Black on Black
chrismmm is offline   Reply With Quote
Old 02-03-2014, 10:52 AM   #3
Unhappy
No connectors loose. Replaced dash and ignition switch. I was thinking it might be a relay. All fuses are good. Was told it could be the ignition switch but with a new one installed I still have this problem. I don't, unless I need to, want to take it to a Porsche dealer. Just don't have that kind of $$.
Old 02-03-2014, 03:34 PM   #4
Did you check the ground connection for the electronics. I looked at the wiring don't see any relays. You checked both b1 and b10 fuses.
rocartfe2 is offline   Reply With Quote
Old 02-03-2014, 04:15 PM   #5
chrismmm's Avatar
relook
You said no loose connector. I understand. Look in the male portion of the pins. Are any crushed down or missing? You said it was working before correct?
Chris M
Old 02-03-2014, 05:17 PM   #6
Registered Boxster abuser
healthservices's Avatar
Originally Posted by irelandmoss View Post
A 1998 Porsche Boxter. Tach, speedo, ect...
Specifically... what is ect?
Ask yourself, what is common with all of these gauges?
Power?
Ground?
Then go from there.
Old 02-04-2014, 04:19 PM   #7
Unhappy
etc. no fuel gauge working, no digital readout
Old 02-05-2014, 02:32 PM   #8
Told by a porsche dealer that there is no relay for the cluster. He said they had problems with the cluster in later model boxters. But there is a fuse. Will be checking that when the weather gets better.
Old 02-05-2014, 03:06 PM   #9
Steve Tinker's Avatar
I thought you said in post #3 that all the fuses were good.....now I am confused.
Note: relays are usually only used when the electrical load is high - as in lights, fan motors, A/C etc. Interior dash lights are a small load and are electrically operated directly by the on/off switch.
2001 MV Agusta F4.
