Old 01-19-2014, 08:06 PM   #1
Caliper painting
Has anyone tried using one of these off the shelf caliper painting kits? (like the one they sell in Pelican). Any reviews or recommendations? I'm curious if you need to strip or grind the existing paint off the caliper before applying the new paint. Is powder coating a better option? If so, can anyone tell me about how much that costs to have done, and a recommendation for a place to get it done in the Los Angeles area?
Dave2001S is offline   Reply With Quote
Old 01-19-2014, 09:41 PM   #2
Registered Boxster abuser
healthservices's Avatar
I have gone thru no less than 5 boxsters in the last 5 years and everyone of them was painted with the off the shelf ceramic caliper paint, stencils from ebay followed upped with some more off the shelf wheel clear-coat in a spray can from the automotive store.
Best part is if your ever need to touch up or repaint, the correct color is as close as the parts store.
If you powder coat, the only proper way is to tear down the caliper and put new seals afterwards.
Old 01-20-2014, 05:00 AM   #3
Rennzenn
j.fro's Avatar
+1 on the off the shelf caliper paint. I used the G2 stuff and sprayed it through my airbrush. I had to thin the paint a bit to get the right flow. It turned out great and seems more durable than the stock finish.
The key is to remove the calipers and take your time. You don't have to remove all the paint, just sand/smooth edges and chips. Clean them really we'll with denatured alcohol before spraying.
Old 01-20-2014, 06:23 AM   #4
Meticulous surface preparation is everything. You can obviously do a better job if you remove the calipers from the car. A few cans of brake cleaner, a wire brush, and lots of rags should do the trick. Plug the holes with rubber stoppers and tape off the seals.
I used VHT caliper paint and it seems to be holding up well.
'99 black 986
Old 01-20-2014, 07:25 AM   #5
Strive For Fame
Corrington's Avatar
Send a message via Skype™ to Corrington
I agree, the automotive store method is much easier. I regret powdercoating.
Strive For Fame
2000 Porsche Boxster S
2008 Lamborghini Gallardo
2010 Kawasaki Ninja
1996 Suzuki Bandit
Corrington is offline   Reply With Quote
Old 01-20-2014, 07:54 AM   #6
BruceH's Avatar
I did the same, brake cleaner, wire brush, some sand paper, clean, mask, VHT red, stickers from eBay, and then VHT clear.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-20-2014, 08:30 AM   #7
Awesome comments, thanks! I'm going to try it.
Old 01-20-2014, 09:01 AM   #8
Dlirium's Avatar
Post a link to the caliper stickers that are mentioned if you find them on Ebay...
Old 01-20-2014, 09:15 AM   #9
BruceH's Avatar
Here you go:
6 Porsche Prem High Performance Brake Caliper Decals | eBay
DEPO Tail Lights
Old 01-20-2014, 10:09 AM   #10
porsche caliper stencils | eBay
I like the stencils better as you use paint instead of a sticker.
just make sure to use the correct size, as there are fanatics will point out that they are incorrect if too big or small. :ah:
Old 01-20-2014, 07:30 AM   #11
doragman's Avatar
Did mine last year, Dupli-Color brush on, and very happy with results.
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 01-20-2014, 08:34 AM   #12
And although you can carefully tape everything off I found it easier to just removing them and re-bleeding the brakes. this is on a Cayenne I did..
Old 01-20-2014, 05:28 PM   #13
LAP1DOUG's Avatar
Man, I have to try fitting some of those Cayenne calipers on my 986S. Wonder if they make pads for it in RS-14 or DS-11 compound.
Kippis
986S
991S
Van Diemen RF97
Old 01-20-2014, 06:40 PM   #14
Looks awesome. Did any of you go through the step of baking the calipers between coats? I wonder if that's really necessary. Also, if you use the Ebay decals, I assume applying the clear coat is a must.....or is it?
Old 01-20-2014, 06:45 PM   #15
BruceH's Avatar
........Also, if you use the Ebay decals, I assume applying the clear coat is a must.....or is it?
It is IMO. The calipers never leave the vehicle with the paint method so no baking.
DEPO Tail Lights
Old 01-21-2014, 03:41 PM   #16
woodsman's Avatar
Old 01-26-2014, 03:51 PM   #17
I just noticed that the caliper connecting lines are painted on my car. I'd like to have those be a bare metal look, but how to strip the paint off them? New ones cost $50 each.
Old 01-20-2014, 06:55 PM   #18
com3dorm3's Avatar
Whoa, those Cayenne brakes look beefy!
I also found easier to remove the calipers.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 01-21-2014, 07:24 AM   #19
Nice! Do you guys prefer the aerosol spray can methods/products, or are the paint can and brush products better? I saw a YouTube video that shows the use of an aerosol primer along with the Dupli-Color kit. Any experience with that?
Old 01-21-2014, 03:31 PM   #20
woodsman's Avatar
