Old 01-01-2014, 12:32 PM   #1
steved0x's Avatar
How in the *f* do you remove the clutch slave bleed nipple cover?
It feels like it is made of ridgy black metal material. I can spin it, but it doesn't seem to thread off. I have tried pulling it, and even got a pair of vice grips on it (weakly) and I can't get it to come off. Is there some simple trick I am missing? It seems to be made of a harder material than the brake bleed nipple cover.
I am thrashing around in frustration
Steve
Old 01-01-2014, 12:39 PM   #2
LAP1DOUG's Avatar
Mine seems to be identical to the brake bleed nipple covers. Try prying off with a screw driver if you can get it up in there.
Good luck
Kippis
986S
991S
Van Diemen RF97
Old 01-01-2014, 12:43 PM   #3
Steve Tinker's Avatar
Your right Steve - very awkward thing to get off.
I managed to get a small terminal screwdriver under the lip and prise it off. IIRC, the nipple boot is similar to the brake caliper nipple rubber boots , but the heat from the engine seems to make the one on the slave go hard.
2001 MV Agusta F4.
Old 01-01-2014, 12:43 PM   #4
steved0x's Avatar
Screwdriver... will try... I have a tiny one. Man that is a tight space in there.
Old 01-01-2014, 01:09 PM   #5
Ha - you think that's a tight space - wait until you remove and replace the slave cylinder......
Sometimes its handy to be cross eyed, 4ft tall with 3 arms & 18 fingers all of different lengths. Women don't find me attractive, but I'm good at getting into tight spaces.....
2001 MV Agusta F4.
Old 01-01-2014, 12:55 PM   #6
A small right-angle pic should get under the edge of the cap and allow you to pull it off.
'99 black 986
Old 01-01-2014, 01:17 PM   #7
The Radium King's Avatar
imagine trying to do it with the undertray in place ...
Old 01-01-2014, 01:21 PM   #8
Beginner
Jamesp's Avatar
Amazingly I took mine off about an hour ago. It pries off like a brake bleeder cap. The way I did it was pry it with a screwdiver, and turn it, repeat a little more aggressively each time. I expected it to split (2003) but it eventually pried off.
Old 01-01-2014, 01:23 PM   #9
Beginner
Jamesp's Avatar
It was a pain, and that was with the transmission and transaxle out of the car.
Old 01-01-2014, 01:45 PM   #10
I came here to say one thing
"nipple... hehe"
Black on Black 2001 Boxster Base
Clutch Masters Stage III Clutch
Luk Flywheel // IMS Retrofit // Rear Main Seal
alanqning is offline   Reply With Quote
Old 01-01-2014, 01:54 PM   #11
Brad Roberts's Avatar
I wish I could "thumbs up" you.. LOL
Old 01-01-2014, 02:03 PM   #12
steved0x's Avatar
I have that exact hook tool kit, have used it several times... I finally got this cover off, it was hard as a rock, I had to break it off... Tomorrow I will try and see if I can find a replacement. Fun and good for another two years
Old 01-01-2014, 02:05 PM   #13
Leave it off.. no need for a replacement. I haven't ran bleeder nipples on cars since 02 or so.. with ZERO issues. Worried? Shoot brake clean into the nozzles before you bleed.
Old 01-06-2014, 05:24 AM   #14
steved0x's Avatar
I can live with that! All buttoned back up with no plastic cap
I got an 11mm stubby for next time. Which I hope is a long time from now.
Steve
