Old 06-11-2002, 03:09 AM   #1
K&N / oil filters and MAF sensor
Recently I blew my Impreza engine because of a faulty MAF (Main AirFlow) sensor. The sensor gave a low voltage, so the ECU sees less air than actually comes in, so the ECU provides less fuel, result is a lean mixture, result is knock, result is a hole in piston (turbo engines are very sensitive to knock and air/fuel mixture)
Subaru says the K&N 57i (cone style) filter is the reason why the MAF failed. Oil from the filter polluted the MAF sensor. No warrenty whatsoever.
My BoxsterS is equipped with a K&N replacement filter, fitted by the dealer. He wouldn't fit a open style (57i) filter / induction kit in the warrenty period.
I'm a bit worried now, any suggestions / experiences ?
Mark.
markk is offline   Reply With Quote
