Old 12-21-2013, 12:36 AM   #6
Steve Tinker's Avatar
Originally Posted by nieuwhzn View Post
Resetting to the default maps could result in your car initially idling and running like crap. You have to put a couple of hundred miles on it to get your maps rebuild.
It's not the miles that "resets" the maps but the quantity of completed heat cycles - cold start up to full running temperature down to ambient again.
It usually takes 3 or 4 cycles from disconnecting the battery for the ECU to revert back to stock settings. Using the procedure as I described above quickens the effect without the car running poorly for a few days.
2001 MV Agusta F4.
