Old 12-19-2013, 12:04 PM   #1
correct tyre pressure
I have a 99 986 but it has the 993 turbo wheels on with pirelli p zero rossos. The fronts are 235/35 19" and the rears are 275/30 19". Can anyone tell me the correct pressure for these tyres please?
boxster is offline   Reply With Quote
Old 12-20-2013, 06:54 PM   #2
Joe B's Avatar
Look in the owner's manual (RTFM...I always wanted to say that ). Start at 29 F/36R, that's what Porsche recommends for OEM tires/wheels (I run 30F/34R).
Old 12-20-2013, 08:23 PM   #3
I run 30/36 on 19's. When you drive for about 15 minutes PSI increases about 2-3 lbs all around.
2003 Boxster S
ohhh my is offline   Reply With Quote
Old 12-20-2013, 08:44 PM   #4
Agree - start with 29F/36R and then adjust to suit your taste.
I run 30psi all around. But that's me and my specific tires. Your mileage will vary.
Old 12-21-2013, 07:33 AM   #5
BYprodriver's Avatar
18" maximum
Old 12-21-2013, 01:49 PM   #6
Joe B's Avatar
18" maximum
Huh ? Does that matter?
Old 12-21-2013, 10:13 PM   #7
Thanks for the info guys. Ill go with 29 f and 36 r and see how it goes. At the moment i was keeping them 28 all around but i. Sure it needs to be more than that
Old 12-22-2013, 01:41 PM   #8
2004 Boxster S
evan9eleven's Avatar
I've been meaning to ask the same question. I'm running oem sizes on 18" wheels and my indi put all four corners at about 30psi after a recent tire change. Car handled great like this. Then I tried upping the rears to about 35psi and it didn't take long before a little stomp on the throttle broke rear traction for a split second getting on an on-ramp. I'm thinking about dropping back to 30 all the way around. Anyone else running lower then stock pressure out back?
evan9eleven is offline   Reply With Quote
Old 12-22-2013, 02:46 PM   #9
Joe B's Avatar
I run 34 rear. Maybe you hit an oily spot.
