Old 12-01-2013, 03:56 PM   #1
O2 Sensor success
I finally got the Boxstar out of the shop from its Exxon Valdez imitation(timing tool will be for sale shortly) and did what I plan to do; replace the O2 sensors. Using the 101 book for guidance, it took me 3 hours on the first one and 1 hour on the next. The book failed to mention the red clips that hold the connectors in. After the install, I ran a diagnostic and everything is within tolerances. Took it out for a run and so far no CEL light! Hopefully success!!
davedeck is offline   Reply With Quote
Old 12-05-2013, 03:35 AM   #2
Guvs's Avatar
Keep us informed if the CEL comes back on will you.
Guvs.
Guvs is offline   Reply With Quote
Old 12-05-2013, 07:05 AM   #3
3 hours for a O2 sensor replacement seems way too much. I recall a single one taking 20 minutes and that was mostly waiting for the cats to cool down a bit so you'd want to get your hand near it. A lift really helps. As does the right tool to break loose the sensor.
Old 12-05-2013, 08:10 AM   #4
jakesbox
trimer's Avatar
what are the tolerances?
Old 12-05-2013, 10:08 AM   #5
Wow you must have a kickass car, Boxstar, I only have a Boxster. You lucky lucky bastard!
Old 12-06-2013, 04:54 PM   #6
I agree 3 hours is too long but that included making the plug from Bosch's universal kit and I couldn't see the red clip holding it so I spent considerable time pulling and pushing on the plug. And running to O'Reillys for a 22mm wrench
