-   -   O2 Sensor success (http://986forum.com/forums/performance-technical-chat/49674-o2-sensor-success.html)
davedeck 12-01-2013 03:56 PM
O2 Sensor success
I finally got the Boxstar out of the shop from its Exxon Valdez imitation(timing tool will be for sale shortly) and did what I plan to do; replace the O2 sensors. Using the 101 book for guidance, it took me 3 hours on the first one and 1 hour on the next. The book failed to mention the red clips that hold the connectors in. After the install, I ran a diagnostic and everything is within tolerances. Took it out for a run and so far no CEL light! Hopefully success!!
Guvs 12-05-2013 03:35 AM
Keep us informed if the CEL comes back on will you.
Guvs.
mikefocke 12-05-2013 07:05 AM
3 hours for a O2 sensor replacement seems way too much. I recall a single one taking 20 minutes and that was mostly waiting for the cats to cool down a bit so you'd want to get your hand near it. A lift really helps. As does the right tool to break loose the sensor.
trimer 12-05-2013 08:10 AM
what are the tolerances?
Slate 01 12-05-2013 10:08 AM
Wow you must have a kickass car, Boxstar, I only have a Boxster. You lucky lucky bastard!
davedeck 12-06-2013 04:54 PM
I agree 3 hours is too long but that included making the plug from Bosch's universal kit and I couldn't see the red clip holding it so I spent considerable time pulling and pushing on the plug. And running to O'Reillys for a 22mm wrench
