Old 11-17-2013, 08:14 AM   #3
Beginner
Jamesp's Avatar
Warm the car up and pull the plastic battery cover in the Frunk - check the two rubber lines behind the battery - if both good and hot then heater core functioning. If not bleed the air out of the cooling system.
If both hot, a mechanical failure in the mixing valve / door is likely.
Last edited by Jamesp; 11-17-2013 at 08:54 AM. Reason: didn't read original post carefully enough
Tags
heater
