Old 09-11-2015, 11:24 AM   #1
986 alarm issue
Hi I am a new porsche 986 owner 2.7 2002 model.
I wanted to remove dash binnacle but when I disconnect battery the alarm goes off I have to re connect put key in ignition d turn to position 2 to stop it
Is there a way of disabling it or do I need to leave key in the ignition and if so in any particular position I an based near Bristol
Any replies would help Thanks
986wsm is offline   Reply With Quote
Old 09-11-2015, 02:16 PM   #2
Any answers welcome
Old 09-11-2015, 11:54 PM   #3
Key in position 1, disconnect battery then remove key. Alarm goes off when battery disconnected as a security measure.
mmarksx19 is offline   Reply With Quote
Old 09-12-2015, 12:36 AM   #4
Ok I will try that -and what is the procedure for reconnecting battery ???
Old 09-12-2015, 07:36 AM   #5
Just reconnect
Old 09-12-2015, 10:41 AM   #6
Ok thanks will try Sunday
Old 09-15-2015, 01:35 PM   #7
Thanks worked a treat. A lot easier than wiring in the dash led that shows where spoiler is at either up down or in movement up or down
The mollex connector on green plug had so many wires on it adding a further 5 made it very hard to shut. But managed it and all good now.
Thanks for the alarm info.
