Old 04-24-2008, 04:52 PM   #1
Send a message via AIM to PSL-Boxster
cooling fans
i drove my box today to go get pizza ( yum ), and i didnt really drive it that hard. the highest rpm i got up to was about 5k and i didnt exceed over half throttle...after i got home (and ate my delicious pizza) i went by the garage and heard the cooling fan running, 30 minutes after i shut the car off...is this normal? i do this exact same procedure about once a week and haven't had this happen.. i kno if you run the car quite hard (track), then the cooling fan will stay on after you shut the car off so that it can cool...but after a regular drive? --> can i have a cooling problem? >_> thanks
PSL-Boxster is offline   Reply With Quote
Old 04-24-2008, 11:25 PM   #2
Lil bastard's Avatar
I think you have either a failed Cooling Fan relay - #s 19, 20, 21, 22 in the kick panel Relay Panel, or you have a failed Engine Coolant Temperature sensor - located on the left front of the engine, accessible through the engine access panel. This ECT sensor signals the DME to activate the Cooling Fans.
There are other possibilities, but these are the most likely.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-25-2008, 01:06 AM   #3
yup, i'd check with what he said.
but i'll take this opportune time to mention that about once a year, its a good idea, to clean out the dirt in front of each radiator.
i remove the front bumper, (20 minutes). then remove the trim around the radiators, then pull the radiator loose. there is always a lot of debris, it looks like a mini forest with cig butts leaves, etc.
i dust it out, you can use air, or a little dust pan duster. then i follow that up with a hose. then i put it all back together.
http://b-ng.com/audi/images/avatar.jpg
Benny
lubrify.com
Benny986 is offline   Reply With Quote
Old 04-25-2008, 02:09 AM   #4
What fan? For the radiator or the engine compartment?
Tool Pants is offline   Reply With Quote
Old 04-25-2008, 07:10 AM   #5
Brucelee's Avatar
Yes, 30 minute is too long.
Ditto, check radiators in front for debris etc.
Rich Belloff
Old 04-25-2008, 09:16 AM   #6
Yes, checking the radiators at least bi-annually s/b considered scheduled maintenance for these cars.
But I suspect that if that were the issue here, he'd see an abnormal Temp gauge reading which wasn't reported.
I think it's an electrical issue and not temp related.
One other thing - best to address this sooner rather than later to avoid possibly discharging the battery and create possible charging problems, now or in the near future.
1976 BMW 2002
1990 BMW 325is
Old 06-19-2008, 05:13 AM   #7
I notice a similar thing. The fan I hear is behind the passenger seat somewhere.
I used to notice that it would come on periodically, but now it sounds louder and makes an almost grinding noise as it starts up. What fan is this, and what could be going on?
Richard Griffin
Atlanta GA
2001 blk/tan Boxster 18" turbo twist wheels
2003 gray/tan Navigator
rgriffin is offline   Reply With Quote
Old 06-19-2008, 08:24 AM   #8
That's the engine bay cooling fan. It should trigger once the temp in the engine bay reaches 180° F. It is not part of the engine cooling system. It's function is to reduce heat in the engine bay to prevent the charge from being too hot and to reduce the threat of fire - a concern for all mid-engine cars. You won't notice it when driving usually because sufficient air is drawn in the passenger side vent to keep the engine bay temps lower than 180, but idling, or in stop&go traffic, it should come on.
From your description, it sounds as if you have a bearing going bad in the fan motor. Plan on replacement sooner rather than later I'm afraid.
1976 BMW 2002
1990 BMW 325is
Old 10-20-2013, 03:56 PM   #9
cooling fans
Hi, Does anyone know if both fans should run at same time with only engine running and A/C off ? Only the left fan runs at low speed with engine running. If I turn a/c on both fans run at high speed. 1999 Boxster
lawn1 is offline   Reply With Quote
Old 10-22-2013, 11:39 AM   #10
Trey T's Avatar
As long as can remember my SO's Boxster engine fan comes on for short period of time (30sec to 1min) even after engine is off.
I always thought that was normal; is it not?
Trey T is offline   Reply With Quote
Old 10-22-2013, 05:20 PM   #11
My fans have never come on after i have turned off the engine... Anyone else experience the same?
ohhh my is offline   Reply With Quote
