I think you have either a failed Cooling Fan relay - #s 19, 20, 21, 22 in the kick panel Relay Panel, or you have a failed Engine Coolant Temperature sensor - located on the left front of the engine, accessible through the engine access panel. This ECT sensor signals the DME to activate the Cooling Fans.
There are other possibilities, but these are the most likely.
