Old 09-17-2013, 08:36 AM   #1
DIY extremist
black_box's Avatar
New(ish) Engine and Rebuilt Turbo Break-in Oil
Not actually a Porsche-related question, but you guys seem to know a lot about motors in general.
I am wrapping up an engine swap on my DD, a 2007 MINI Cooper S that sharted its original engine at 165k and is getting a lowered-compression, ported head, forged piston 8k mile 2011 MINI J.C. Works motor, along with an hybrid k03/k04 turbo, ported manifold, 3" downpipe, new clutch, radiator, and a water/methanol injection to keep everything happy. Looking forward to a 240 FWHP MINI monster that still gets 40 MPGs and handles on (tiny) rails!
The motor sat with fluids drained for about a year, and the turbo is freshly rebuilt.
I am planning to run full synthetic with 7500 miles changes just like I do on my Porsche, but am thinking of running ~1k on dino oil to "break-in" the motor and turbo and then dump and refill with synthetic. I won't crank the boost up until it's done some miles on the new setup (stock ECU boost limit is approx. 15PSI, I am planning to slowly increment up to 21PSI, the max safe boost that the JCW motor can handle).
Any ideas for "break-in" on a motor that's sat awhile? Both the motor and turbo have warranties, although I'd hate to try to exercise them.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 09-18-2013, 09:17 AM   #2
DIY extremist
black_box's Avatar
no one knows how to bring a sitting motor back to life?
Old 09-18-2013, 10:47 AM   #3
Track rat
Topless's Avatar
Break-in procedures are usually motor specific and vary based on motor design. Consult Mini for their recommendations. Here is the factory procedure for a recent vintage GM 5.3L:
Break-In Procedures
After installing the engine, ensure the crankcase has been filled with the correct (refer to instruction sheets that come
with the crate engine) motor oil (non-synthetic) to the recommended oil fill level on the dipstick. Also check and fill as
required any other necessary fluids such as coolant, power steering fluid, etc.
The engine should be primed with oil prior to starting. Do this by using an engine oil priming tool. If you do not have one,
one can be obtained through GM, part number 12368084. Follow the instructions enclosed with the tool. This is the sure
way to get oil to the bearings before you start the engine for the first time. Also, prime the engine if it sits for extended
periods of time.
Safety first. If the vehicle is on the ground, be sure the emergency brake is set, the wheels are chocked and the car
cannot fall into gear.
Start the engine and adjust the initial timing. Set the ignition timing to timing specified in the instruction sheet and the
engine idle to the speed as specified in the instruction sheet. Rotate the distributor counterclockwise to advance the
timing. Rotate the distributor clockwise to retard the timing. Leave the vacuum advance disconnected.
When possible, you should always allow the engine to warm up prior to driving. It is a good practice to allow the oil sump
and water temperature to reach 180° F before towing heavy loads or performing hard acceleration runs.
Once the engine is warm, set the total advance timing as specified in the instruction sheet.
The engine should be driven at varying loads and conditions for the first 30 miles or one hour without wide open throttle
(WOT) or sustained high RPM accelerations.
Run five or six medium throttle (50%) accelerations to about 4000 rpm and 55 mph (if application is a vehicle), and back
to idle (0% throttle) in gear.
Run two or three hard throttle (WOT 100%) accelerations to about 5000 rpm and 55 mph (if application is a vehicle), and
back to idle (0% throttle) in gear.
Change the oil and filter. Replace with 20W50 racing motor oil (not synthetic) and an ACDelco oil filter. Inspect the oil and
the oil filter for any foreign particles to ensure that the engine is functioning properly.
Drive the next 500 miles (or 12 to 15 engine hours) under normal conditions. Do not run the engine at its maximum rated
engine speed. Also, do not expose the engine to extended periods of high load.
Change the oil and filter. Again, inspect the oil and oil filter for any foreign particles to ensure that the engine is
Do not use synthetic oil for break-in. It would only be suitable to use synthetic motor oil after the second recommended
oil change and mileage accumulation.
