Old 08-29-2013, 06:03 AM   #1
Rob Vine
Robsducati's Avatar
Misfire and fault code
Hi
Had a misfire and engine warning light come on, bought a Porsche PIWIS cable to carry out some diagnostics and it came out with the codes below:
My guess, before I get underneath it, is to look at coils and plugs on cylinder 6. However if anybody has had a code like this and found something else that has caused it, I would be very interested get their opinion.
Rob Vine
2004 Boxster S
Ducati 749S
1993 928GTS sold
Robsducati is offline   Reply With Quote
Old 08-29-2013, 06:43 AM   #2
I don't know if the older version of Durametric has Freeze Frame data access. If so, check that and post it here. Misfires are not necessarily caused by ignition issues -- can be mechanical or fuel delivery problems. Also, go to the actual values section on the Durametric and watch the misfire counts for that cylinder at idle and under higher rpms.
Regards,
paul...
paulv is offline   Reply With Quote
Old 08-29-2013, 08:13 AM   #3
Rob Vine
Robsducati's Avatar
That should be it then!
Just removed the cylinder 6 coil pack (see below) guess I need a new one!
Rob Vine
2004 Boxster S
Ducati 749S
1993 928GTS sold
Old 08-29-2013, 09:14 AM   #4
You certainly do need a new coil pack. You may still want to watch the misfires in the actual values to see if thee are other cylinders that are misfiring but not enough to reach the threshold to set a DTC.
Regards,
paul...
Old 08-29-2013, 09:22 AM   #5
Hi
I'd be careful about relying on that diagnostics system; the current version of the Durametric software is Version 6.3.1.7, and it has fixed a lot of the bugs found in the early system.
Old 08-29-2013, 11:44 AM   #6
FYI: Check the other five coils packs - they are likely to be near the same condition. You may want to replace all 6 while you're in there.
Old 08-29-2013, 05:54 PM   #7
993innc's Avatar
Could it be possible that all the coil packs could be shot (not pertaining to this thread but mine)? I too threw a P0300 (also 0107 and 0343) as one of my codes. Guess I'll add that to the list of items to look at in chasing my starting/running issues!
Chris
- 1997 993 (started it all) - 1975 914 1.8L w/F.I. (restoring now) - 1985 "1958" 356 Speedster (cruiser until 914 is complete)- 2002 Boxster (future, ney...current! track car)
RENT ME FOR YOUR NEXT VACATION: www.vrbo.com/489534 or www.vrbo.com/499924
993innc is offline   Reply With Quote
Old 09-02-2013, 08:38 AM   #8
Rob Vine
Robsducati's Avatar
Fitted the new coil pack and all is well.....You do get a bit paranoid when the dreaded engine light blinks at you after reading some of the posts on this site!
Saying that, the advice you get on here is excellent.
Thanks all.
Rob Vine
2004 Boxster S
Ducati 749S
1993 928GTS sold
