Old 08-21-2013, 12:50 PM   #1
should i change spark plugs?
I have a base 986 which i hardly ever use. Im not sure i cover 1000 miles a year in it. Regarding servicing i make it a point to still change the oil and filter every year. This morning i realised that its been close to 4 years since i last changed the spark plugs. That means that maybe theyve got just over 3000 miles on them. Should i still change them? I use denso iridium.
Thanks in advance
boxster is offline   Reply With Quote
Old 08-21-2013, 01:45 PM   #2
mountainman's Avatar
I just changed mine at almost 50K and they looked perfect. Can't tell any difference in performance or fuel milage. I'd say you were good for a while.
Old 08-21-2013, 02:02 PM   #3
Realistically, you should replace the plugs at least every 4-5 years, regardless of mileage. This is to prevent the steel plug from taking a seat to the aluminum head. Use a small dab of anti seize, torque to spec, drive it like you stole it..............
Old 08-21-2013, 06:54 PM   #4
With so few miles per year, I'd think about doing a major service on 5 yr intervals (coolant, coolant cap, brake fluid, plugs, fuel filter, etc). Otherwise it might take 15 years before you do any maintenance.
Old 08-22-2013, 11:08 AM   #5
thanks for the info guys. regarding coolant, I change it every 3 years, and oil and filter every year. its the plugs i find not necessary to change often.
but i think its time I took them out to check them at least!
What do you guys think about the Denso iridium plugs? Any recommendations?
Old 08-22-2013, 01:19 PM   #6
They are an excellent plug, just be sure to get the correct heat range.
Old 08-22-2013, 01:23 PM   #7
BYprodriver's Avatar
JFP, any speculation why Bosch & NGK seem to be going away from 4 electrode plugs?
Old 08-22-2013, 03:14 PM   #8
Simple: The Iridium's out perform and out last the multi electrode plugs
Old 08-22-2013, 04:15 PM   #9
I realize that but Bosch recently discontinued their Iridium 4 electrode plug for 986s & I couldn't find a NGK replacement either. My local supplier said Bosch recalled the plugs off their shelf.
Old 08-22-2013, 05:20 PM   #10
pjq
Wow, today I just installed 6 new Bosch FGR 6 KQE plugs in my 2004 S 3.2L. Is there a problem with these plugs?
Old 08-22-2013, 06:21 PM   #11
I think you are referring to the Bosch "Platinum Ir Fusion" plug that is a hybrid of both Iridium and Platinum plug technologies. It uses Yttrium side electrodes and a Platinum and Iridium center electrode:
I had heard there had been problems with the side electrodes.
The Iridium's we use are single side electrode Denso's, and they have been working very well for us.
Old 08-23-2013, 08:36 AM   #12
I have a 1999 Boxster and I change the plugs every 30,000 miles.
I do believe there is not a true need to change them that often, but I do it myself and plugs are cheap.
I use Bosch 4-electrode "Platinum Ir Fusion" #4503 plugs.
I get them from RockAuto for $6.16 per plug. The last time I purchased them from RockAuto I got a $24.00 rebate.
Based upon this thread "Should I Change Plugs?", I just ordered a new set. Unfortunately now RockAuto only sells them in packs of 8.
And the rebate is still available until 31 Dec 2013.
I see this as a win win situation.
Just my two cents.
MNC-I
mnc-i is offline   Reply With Quote
Old 08-23-2013, 11:37 AM   #13
Yes that's what I was referring to, Bosch 4503 I think. Looks like they changed the side electrodes.
Old 08-26-2013, 05:17 AM   #14
Thanks for the info guys. I think i will continue to use denso iridium though. I will get them checked out at the next service
