Old 08-12-2013, 03:08 AM   #1
HELP - Water, Oil, Fuel Indicators after removing battery/cluster
I hope someone can help with this and its a simple fix....
I recently disconnected the battery and removed the instrument cluster to fit a microphone on the dash for a handsfree kit. When all reconnected and started the ignition four warning indicators appeared;
Failure of Outside Temp Indicator
Failure of Oil Indicator
Failure of Fuel Level Indicator (Drive to Workshop)
Refill Washer Fluid
I know all the levels were fine prior to disconnecting the cluster and battery, is it a fuse that is common to all or is it more serious? Has anyone else had this?
Many thanks in advance.
Tall_Paul is offline   Reply With Quote
Old 08-12-2013, 03:09 AM   #2
Sorry, should have said its a 2003 Boxster S
Old 08-12-2013, 04:46 AM   #3
Spinnaker's Avatar
Not the same problem, but similar. See if this helps.
Boxster Odometer Problem - Rennlist Discussion Forums
Old 08-12-2013, 10:07 AM   #4
No, tried the key position 1 when battery removed and still no joy...
Been through all the fuses and nothing blown.....
Anyone help?
Old 08-12-2013, 01:26 PM   #5
I believe that all of those are on the same connector. Try pulling and re-seating all of the connectors
Old 08-13-2013, 04:58 AM   #6
Many thanks Particlewave..although the retainers clicked into place the connectors weren't fully home. Cheers
Old 08-13-2013, 09:26 AM   #7
Excellent! Glad you got it fixed
