Old 08-07-2013, 10:20 AM   #2
The Radium King's Avatar
disconnect the battery to reset the ecu - the computer may still have some adaptations from when the idle sensor was fouled.
check the front of the engine - belt, idler pulleys, water pump, alternator, ac. remove the belt and check all pulleys for play and resistance.
check engine vacuum - a vacuum leak can mess with air/fuel sensing.
