07-24-2013, 01:57 PM
Reprogramming ECU to turn off O2 Sensors
I've deleted my cats with a test pipe and the shop is telling me that I need to reflash my ECU with the cats deleted. Does anyone know of a company I can send the ECU to?
2003 911 C2
NASA HPDE Instructor
07-24-2013, 03:15 PM
Moderator
97-99 or 00-04? You don't have to reflash ECU when you delete cats. You can tune an ECU to make more power, however many people including myself are content with just the increase from removal. Are you getting a check engine light? You can flash it or just add some 02 sensor extensions to remedy the problem.
Edit: It looks like your car falls in the 97-99 range judging from you car pics. You would probably be throwing a check engine light then.
07-24-2013, 03:25 PM
I have a pretty strange problem. I removed the cats and the car ran fine. Then after making a different repair I unhooked the battery and reconnected it and the car started misfiring on all 6 cylinders. Both Porsche shops I've taken it to have told me that the problem is the removed cats and that I have to do something with the rear o2 sensors. And yes the check engine light is on.
2003 911 C2
07-25-2013, 10:07 PM
Boxster Abuser
Originally Posted by truegearhead
Then after making a different repair I unhooked the battery and reconnected it and the car started misfiring on 6
What was the other repair?
4.0L Dry Sump Boxster GT race car - HRG #23
2005 Cayenne S - DD
07-26-2013, 04:17 AM
Thanks so much for your help.
Full story
1) Car refused to start, just clicked. The battery was old so I just went ahead and replaced it (never jump started the car)
2)with the new battery it started but misfired on bank 1
3) I towed the car in and they told me the AOS and oil fill tube failed so I replaced them
4) I got the car back and it didnt red line and still ran rough. They told me the variocam was bad and I had a bad cat.
5) I replaced the cats with test pipes and it ran great but wouldn't redline
6) I replaced the variocam and the car ran but wouldn't redline. I tried disconnecting the battery to reset the ecu and ended back at step 2). Except I now have a misfire on all cylinders. By the way steps 1-6 are over 3-4 weeks, only 1 week spent out of the shop.
2003 911 C2
07-24-2013, 07:37 PM
Moderator
That is certainly strange. Dunno if a misfire and the cats missing could be related, or coincidence. Haven't heard of that on the forums, but is there a way to find the codes?
07-25-2013, 04:54 AM
Its reporting a misfire on all 6 and a code for e-trottle relay which is odd since its a 97
2003 911 C2
07-25-2013, 07:00 AM
Both shops are mistaken because the o2 sensors aft of the cats only sniff for emissions and don't affect mixture trims. I would disconnect the batt again for one minute to reset the DME and see what you get. Is it possible you crossed the pos/neg terminals and fried your DME?
07-25-2013, 07:17 AM
No the cords don't reach. This happened once before a month ago and I towed the car in and it was diagnosed with a bad air/oil separater. After the fix it ran, then once I dissconnected the battery again..same thing all over again. I've dissconnected it numerous times and connected them to discharge and capacitance..no luck. Very odd problem. Are you sure the aft O2's don't effect mix?
2003 911 C2
07-25-2013, 12:25 PM
Any shop with a PSTII or Piwis can flash it with a "ROW" tune.
It turns off the secondary 02's and does away with the secondary air pump.
Topless is correct, just HANG THE secodary 02's under the car in clean air. They are looking at CAT efficiency. Plug them back in and leave them in the trunk somewhere.. seriously.. plug them back in and let them *see* clean air.
They are heated, so secure them so they don't touch carpet. Up against plastic is fine.
07-25-2013, 12:32 PM
I would just do a RoW flash and then you can completely remove them, along with all of the secondary air injection guts.
This has the other nice benefit (at least to me) of being able to start the car without depressing the clutch.
Boxster S
07-25-2013, 12:33 PM
I have bypassed all my cars at the ECU lol
I actually forgot that the ROW tune removes it lol
07-26-2013, 09:39 AM
Dude.. (SoCal term for cool guy)
Please get your car out of that shop that has NO clue about your car..
Here is the MAP to Charlottesville:
Kenny Shreves runs a shop there and is a factory trained Porsche tech who happens to be a PRO race mechanic for teams like Flying Lizard, Park Place and many others... He is VERY VERY good at what he does. I'm glad to call him "FRIEND" and I don't mean facebook "friend"
All it takes is for this *shop* to leave a ground wire off for the coil packs and you will have a ton of weird ass problems.
https://maps.google.com/maps?saddr=Richmond,+VA&daddr=Charlottesville,+VA&hl=en&sll=37.269174,-119.306607&sspn=11.653767,21.687012&geocode=FXXTPAIdcGti-yntyZlXCRGxiTHFPELibT7Yvw%3BFfpHRAIdeopS-ymPpFDqLYaziTH8dIvDlvCGkA&oq=charlo&t=h&mra=ls&z=10
07-30-2013, 10:05 AM
Problem resolved! It was the mass airflow sensor. I haven't picked the car up yet but I'm told its running great. Thanks again for everyone's help. Luckily I didn't replace the ECU like the other shop was telling me to do YIKES! Pays to get a second opinion I guess.
2003 911 C2
07-30-2013, 10:28 AM
Moderator
Glad to hear you got your problem resolved. Man, that sensor must be really bad to cause such misfire. Had a bad sensor once and only symptom was couldn't go past 5k rpm.
07-30-2013, 12:41 PM
Kenny, I would think that depending upon the amount of oil in the throttle body from the blown AOS, the MAF sensor could indeed be that bad!
Brad
07-30-2013, 06:09 PM
Brad
That was my first thought to. Especially after a failed air oil separator but that was one o te first things I checked. I pulle the mass air out and there wasn't a drop. Who knows, something tells me there is something else
2003 911 C2
